jjhoward
 - Northern NJ
 - Owner TJ Electric
Suggestions please:
I am putting together a bid for a 4K sq ft new residence with an overabundance of lighting. This house will be mostly an art gallery. GC wants a 400 amp UG service. (Load analysis TBD, still looking at the plans.)
For the 400 amp, 240V single phase UG service, should I run parallell 2/0 Cu lines or do I pull 4/0 CU through this 85' of 3" PVC?
If I run the parallel conductors, am I OK to run them all in the same conduit?
Never installed any service gear > 200 amp, single phase.
Thank you.
Thank you.
