dakcn
- bothell wa
I installed a new 400 amp meter base service located approximately 175 feet from my house. I am running two 200 amp feeders to the new house each with a 200 amp breaker on the 400 amp service. Inside the house the panels are right next to each other and both panels have a main breaker. The 400 amp meter base service has been inspected but the feeders have not. I have seen this setup before. I was reading the code book the other day and happened on article 225.30 and am now concerned that I can only have one large feeder going into the house which would be split inside. I am now in a panic that it will not pass inspection. Has any out there gone with this setup or can shed any light on 225.30.
Thank you very much for any help you can offer.
Chris
Chris
