electric man 31
- Connecticut
Hi to all!!
I am looking for some help in grounding and bonding a service I am doing.The service in question is a 400 amp 3 phase 4 wire overhead service 120/208volts. My question is where do I tie my grounds into? I am driving 2 ground rods and bonding building steel, also Iam going to hit the main water pipe upon entering the building. I have a main switch with a c.t. cabinet from there I have a main dist. panel that in turn feeds two 200 amp panels. My mainswitch only has one lug in it which says for equiptment grounding elecdrode only, so do I land my driven ground there? If this is correct then do I land my water ground and building steel grounds in the main dist. panel with my sub panel grounds?As you can see I am a little confused on what goes where in this type of application! How about bonding bushings?? where should they go and at what point do I tie them to? Any help in this matter would do me good thanks to all who respond!!!!
