Hello, Im new to the site and was reading the post below about a 400 amp service. Having only installed a 200 amp panel myself I was wondering how you would ground a 400 amp service? If you had 2-200 amp panels could you run 1-#6 wire from 1 panel to a ground rod, and then a #6 wire between the 2 panels? Plus for the cold water ground could you run a wire sized from table 250.66 connecting 1 panel to the cold water pipe and a second wire between the 2 panels? Thank-you.
