I need help looking at a couple of ways to do a farm irrigation service pole. Three phase is out of the question so the farmer would like a "400A service" for future expansion.
No loads or pump other than a 7-1/2 HP single phase pump, a refrigeration truck that occasionally may be plugged in. I believe the refer truck is a 30A twistlock 240V 1 phase. Service is on a pole in a field. I suppose he could add several green houses or another pump and truck in the future.
So far I am thinking 18 Foot clearance since we have a commercial truck and a farm.
The Class 320 meter base I got is rated at 400A non cont. lugs are rated for 1 600kcmil or 2 250kcmil. However when I figure a 400A set I get:
1 set of 350 XHHW AL
400A Service 320A Continuous = 4 CC
Amps 80% Fill
350AL XHHW75?C 250 200 0.5166
Number of Sets 2 400 1.0332 Total Fill
Neutral size 250cmil XHHW75?C 205 164 0.3904
Number of Sets 2 328 0.7808 Total Fill
3" Conduit Mast. EMT since it is a pole.
This is inconsistant with common 400A meter base lugs?
I could also do 1 set of 500 Kcmil copper since I do not have a calculated load over 380A.
I find it strange that the 320A Meterbase lugs are rated for 2 AL 250's. Since this would only be a 328A Service. However the power Co usually sets a 75KVA transformer which would only be 312A.
I convince him 300A service would be enough.
What do you guys typically install for such a farm pole?
Amps 80% Fill
