4160 vac motor conection boxes
harolddean
New member
Illinois
What are the specific code requirements for a 4160 vac 600hp motor connection box in regards to minimum size, distance between phases, clearance between box sides, front and back for the connections.
Re: 4160 vac motor conection boxes
Do you have a 2002 NEC? See section 430.12, its a long section and would be best if you could look at it in the NEC.
The make up can must be large enough to make connections with stress cones. The factory can is large enough. This is a NEMA Standard.
