sparkyguy545
Exception clearly notes "In industrial installations . . ."
Not to be picky, but since it is not defined in Article 100, what is an "Industrial installation"?
It's obvious that a plant that manufactures widgets is an Industrial Installation, but what about other facilities that are not as clear. Specifically, would a Water Treatment Plant or a Wastewater Treatment fall into that category? Most often, these do not have an AHJ, as such. They loosely fall under local self-policing bodies.
In my case, our design and construction projects never have an Inspector of any type involved. It falls on the Design Engineer (in my case me) to make the NEC Code decisions. You want to do what is right, but often there just isn't anyone to ask, except for sources & forums such as this. If a Wastewater Treatment Plant restricts electrical service to only qualified staff, and if they follow a written safety procedure for LOTO (such as 70E), then would they be eligible? I don't want to conclude a local disconnect can be omitted if my analysis is fundamentally flawed.
