xavier2167
- Ohio
- Electrician
Electrical question that i cannot seem to find the answer.
- Determine the MAXIMUM size overload protection permitted for a 480V, 3phase, 15HP continuous duty ac motor, where given the following related info. Assume the value you will select will permit the overload device to carry the motor load and modification of this value is not required.
-Design C
-temperature rise: 40 degrees Celsius
-service factor: 1.12
-name plate ampere rating: 18 amps
Im getting the answer online is 18 • 115%= 20.7 amps.
How is the answer 20.7 amps when the temperature rise is 40 degrees Celsius, and the nec 2017 code book states clearly max you can size overload protection for a motor is 125% of a marked temperature rise 40 degrees celsius or less at 430.32(A)(1)
-Design C
