dwagener
- coarsegold,CA.
Inspector made a call on my fan powered hepa filters in a clean room (qty 8) being on a 20 amp 277 volt circuit. The inspector referenced 430.53 which states 120 volt 20 amp circuit is ok but 1000 volt and less needs to be on a 15 amp circuit. Can someone explain why that would be . Each filter contains a 1/5 hp motor with 1.1 running amps and 1.5 starting amps. Thanks
