[FONT="][FONT="]I was reading through 440 and I am not 100% sure if the disconnect means located with in sight (440.14) is also required for the air handler portion of a traditional split system HVAC, it doesn’t have a hermetic compressor motor like the outside condenser unit. [/FONT][/FONT]
[FONT="][FONT="]In my situation the condenser unit is fed from one circuit and I will install a disconnect with in sight, and the air handler unit is installed inside fed from a a different circuit, wondering if it also requires a disconnecting means within sight? [/FONT][/FONT]
