Can you describe the layout in more detail?Yes the panel does contain a main cb. the big problem is that we are having voltage coming back on the ground and it is tripping the main gfi in the 2000 amp switchgear there are many panels in the building and if these panels are wired wrong I need to look into this more.
Also the transformer IS NOT 277/480 it is a delta connection and is 480 VAC while this is a minor point proper terminology is important in any profession.
