jmsbrush
- Central Florida
This is a grounding question but please read first!!!I installed a a Ct cabinet yesterday. I had paralle runs of 4/0 going into the cabinet from the green pedistal. I went through my my CT's into a NSI block. I landed my Neutral conductor in a seperate NSI as well. From the NSI Blocks I Fed 3 -150 amp Panels. Now the load side of those panels fed three other MLO panels in the house. I took my grounding electrode conductor from the from a concrete encased electrode and ground rods and I bonded to the ct can 1st then straight to neutral NSI block then bonded my CT rated meter. I fed my three 150 amp panels with 2 hots and a neutral. So here's the question?? In the panels with the 150 breakers, Am required to tighten up the green screw on the neutral bus???? I passed my inspection but im having doubts. PLEASE HELP.
