electricman8something
I hooked up a transformer thinking I needed 240 volts but as it turned out I needed 208 Volts single phase. Because I did not have a 208 single phase available I incorporated a buck boost. I hooked the single phase transformer primary to 480 V H1 to L1, H4 to L2, H2 & H3. On the secondary side I connected X2&X3 to ground. my output was 240 Volts.Then I hooked up the buck boost as follows output of 10KVA connected to H4 and X1 , X2&X3 Connected, H3 & H2 connected, H1 & X4 Connected to output and H4 connected to other output. Loads seem all right but transformer is warm. Warmer on top of transformer then on sides. Transformers get warm someone did temp check and said it was 130 degrees
