480 volt delta system
romero07
New member
when your service is 480 volt delta system.Is it required that one of the phases should be bonded to ground.
Re: 480 volt delta system
John is correct that the NEC doesn't require grounding. Some utilities will, and some authorities such as MSHA will want grounding or at least ground fault monitoring.
