Open Neutral
- Inside the Beltway
- Engineer
I've not thought much about delta, wye and neutral since EE 443 w/Prof Klingshirn, or even longer ago, installing 3ph transformers and starters.
But I'm now looking at some plans from an electrician.
Q1) If you're fed with 480/277 wye, and run it 1000 ft to a 480 delta:208/120 wye stepdown transformer; are you required to carry a neutral along with those three legs?
(I've always thought it was "no"....)
Q2) What, if anything, changes when you add 480v 3ph motors upstream of the transformer?
