I am looking at a pole mounted utility provided 3-can xfmr bank with a secondary delta configuration. T1 feeds T2, T2 feeds T3, T3 feeds T1. In the middle of each feed, the phase conductor taps and drops to the service disconnect. However, they also have a neutral coming to the disconnect so initially though it was a 480/277V 3-phase 4W. Voltage L-L across all phases is 480V. However, L1-N = 480V, L2-N = 480V, L3-N = 0V. On the pole, it appears they have the neutral bonded to the 3 cans but they have a jumper going from L3 to ground on the pole hence 0V L3-N. I am thinking the neutral should not have been brought to the service disconnect or it was intended to be a 4-wire system but something is wired incorrectly at the pole. Anybody here on the utility side that can help explain if this is the proper transformer wiring or what it should be? It is an industrial site so no N needed and it does not extend past the service disconnect. Something just does not seem correct.
