Working with an older 480V 3-wire system which I would assume to be a delta. The MCC had voltage meters for each phase (assumed L-G). They were strange so I got the meter out. When I read the voltages, I measured each phase to ground. With the following readings: 306V, 281V and 294V. Had this been a Y system, I would consider the readings strange. Is this typical for a delta? L-L voltages were right on.
