I have to install power for a load panel to feed a 240v/43amp rated load and 2, 120v service outlets. The service options are 480v/277v (3) phase no neutral or 208v/120v. The run is 350ft. If I use the 480 option I'll need to step down the voltage. My question here is what would be my neutral concern for the 120v loads. Now if I use the 208 option I would boost the voltage after the ckt bkr for the 240v load. My question to this is the transformer rating needed either options.
