Jake Benedick
New member
- St. Louis, Missouri, U.S.
Why is the -48v "return" bus not grounded to an earth ground or "ground halo" in the equipment room. Is the -48v return bus "floating"?
In a +24V system the return bus is grounded/bonded to the earth halo or grounding halo...whatever you want to call it.
I understand the use of -48V for corroson issues in sensitive phone equipment. But I'm curious as to WHY the grounding difference between +24V and -48V DC power distribution systems with battery back up? Why are we not to bond/ground to return bus of the -48V system?
