frank134
- Pennsylvania
I'd like to know if there is any code in regard to making right or left turns on 5 kv cable under ground in rigid conduit beside the code on 600 volt or higher radius code.
Also also on manholes
1. is there a certain distance needed between manholes?
2. do you have to have a manhole when making a right or left turn?
I also like to know if you need to run a continuious ground wire from the main outdoor switch were the 4160 comes in and then branches off through underground conduits and goes out to feed additional outdoor switches at various buildings in a complex. These various switches feed 4160delta primary/120/208 wye secondary pad mounted outdoor transformers.
OR
Should each building just have it own separate ground.
OR
