MichaelSandoval
New User
- Glendale Arizona
- Miner
So I want to install 6 L6 30A outlets my question is what size conduet is best to use to run 6 sets of 10gauge wire through to have all 6 boxes on 1 run if that is allowed by code this is residential in USA Arizona the run would be 10' max. Each run will connect to. https://www.
These y splitters will run my miner but the miner needs 2 c13 plugs at 15A each plug the miner uses 12A per plug so I figure that 24A on a 30A breaker with 10g wire should keep me at the 80% rule let me know if this will work thank you all in advance. Or will it be best to do 3 sets on 2 runs ?
