5 wire, 2 phase
BKDog
I apologize for not being able to remember where this question comes from but does anyone have any experience with a "5 wire, 2 phase" installation? I am unable to find an illustration of this. Is this "double 2 phase"? Parallel neutrals would still be a 4 wire system, right?
BKDog
so I actually have 2 sets of "2 phase"
would this be supplying 2 separate panels? what would the voltage be between legs? can I figure this with an RMS formula? Any idea what the application be?
Thanks for your time guys
jim dungar
Wisconsin
PE (Retired) - Power Systems
You need to explain what you are trying to accomplish. Is this mental gymnastics or do you have a real world application?
2-phase is an archaic, and rare, system that was primarily used in heavy industry. Yes, a true 5-wire system is actually two 2-phase systems which share a common reference point. There was no practical connection between the phase conductors of the different systems, and also in fact, the were few practical reasons to use a phase-common conductor voltage in any 2-phase system.
electricalperson
massachusetts
the electricians handbook talks about 2 phase systems. although its interesting to learn about and see, you probably will never actually work on them since they are obsolete. i dont even know if power companies supply 2 phase power anymore. only place where you will see 2 phase is very old factories. how many old factories are around now?
rattus
This system has been described by some authors as a 4-phase system, but it is derived from a single 2-phase system by connecting the CTs of the 2-phase secondaries. The common CTs form the 5th wire--the neutral.
quogueelectric
new york
There used to be an old system which had 2 phases 90 degrees out of phase to create rotating field. It was all but extinct when I switched to commercial in 1984. It was still around on some state run facilities and was being PHASED OUT. I dont know of any in existance now though.
