I have a 50/50A 2 pole breaker installed in a 200a main panel... I used 3/4" thinwall conduit from the panel down to a 3/4" LB, I put a romex connector on the end of the LB and ran 50' of 8/3 with a #10 ground romex out to a 4x4 sq wp j-box mounted on the exterior of the house for an above ground spa hook up and from there I came out with a 6' whip of 3/4" seal tite to be hard wired to the spa. My question is can I fit 6/3 with ground in the existing 3/4" conduit. I used 8/3 with #10 ground and need to replace with 6/3 with #?ground. Also can I just strip back the romex and feed it through the seal tite so I can just run it through the 4x4 wp j-box and the seal tite?? Thanks, JB
