JASMITH7520
i have a "source" audio output rated at less than 50 ohms....My "input" is looking for 1k ohms.....In simple terms (for my boss) why doesn't it work?
It should work just fine. It's good for audio singals when the source impedance is lower than the destination impedance. Voltages matter more.i have a "source" audio output rated at less than 50 ohms....My "input" is looking for 1k ohms.....In simple terms (for my boss) why doesn't it work?
trying to set up my fire alarm panel for internet paging (Yes it's allowed by the AHJ here)It should work just fine. It's good for audio singals when the source impedance is lower than the destination impedance. Voltages matter more.
There's something else wrong. Is this an earphone jack feeding an amplifier input? If so, the volume control of the source will have an effect.
More info. please?
Using a Valcom VIP-801 module at the "master" and at each of the other campus'....If I connect an earbud at the output of either 1 of my "slave" modules i get clear audio but nothing is coming out over my FA speakers. Been thru the programming and such for the FA panel and I hear my amps and speakers turning on but no output....Adjusted the volume to max today and no difference.....Thought maybe there was a problem with my FA ASU (audio source unit) input and the modules output....
Have another source you can try as a test? Or another cable? Are you mixing mono and stereo?If I connect an earbud at the output of either 1 of my "slave" modules i get clear audio but nothing is coming out over my FA speakers. Been thru the programming and such for the FA panel and I hear my amps and speakers turning on but no output.
