Ithinkimstillhere
- saint louis
I need to provide a 500KVA dry type transformer within a manhole. The dimension of the hole is 10'x12'x12'. It will have a sump pump and a drainage inlet.I was thinking about providing a steel grate for ventilation, but how do I elevate the pad in the case of flooding (failed sump)? It needs to be elevated at least 2 to 3 feet I think. This transformer will only be active roughly 3 days out the year for a fourth of July events. Should I order the contractor to provide a steel grate AND a solid liquid tight cover for when the transformer isn't in use?
