i have a situation where the customer is wanting to pull a motorhome into the parking lot next to a church once a year for an annual event. The motor home is set up to run on a 50a 125/250v service. It has 2 air conditioners but does not have any 240v loads inside. All are 120v devices including the air conditioners.
The Service at the church is 208/120 3ph 4w.
Has anyone ever installed a 50a RV outlet on a 120/208v Circuit?
I'm not sure that's even allowed.
They want to be able to run both 120v Air Conditioners. I dont think I can use a Buck Boost transformer to get the voltage to 240v since it most likely will boost the 120v also. If i install a 208 to 120/240v standard transformer it gets really pricy really quick.
I was curious if anyone has run into installing a 50a 125/250v Rv Outlet where there was only a 208/120v service available.
My other option is to install a 30a 120v Rv Outlet and tell them to forget about being able to use the 2nd air conditioner, but i'm sure they'll want to use both.
