50amp 2 pole NC contactor
AndyB
I'm having no luck finding a 50amp 2 pole normally closed contactor 120v coil locally that isn't $500. Everyone has non reversible normally open contactors. Any place online that sells one? Thanks.
LarryFine
Henrico County, VA
Electrical Contractor
You need the contactor to open the main circuit when you receive a voltage, right?
Have that voltage energize a small NC relay to deenergize a standard NO contactor.
petersonra
Northern illinois
engineer
It may be that he wants to feed power from a seperate source on power failure.
Maybe a small ATS would do the trick.
