Re: 50amp cord into 30 amp campground service
No there is no code against it, because everything down line from the 30 amp breaker will handle 30 amps without an overheating problem. That 'cheater' cord you mention is actually U.L. listed. They also make one so that you can plug your 30 amp camper into a 50 amp recept. That is against code because your 30 amp camper and wiring can theoretically take up to 50 amps without tripping. The #10 wire and insulation doesn't like that and the adapters are not U.L. listed.
