511.12 220Vac vers 125Vac GFCI
612John
New member
Dayton, MN
My understanding is all 125Vac outlets in a Commercial Garage will have GFCI protection.
220Vac outlets with a twist lock do not require GFCI.
Does a 125Vac outlet with a twist lock require a GFCI?
The GFCI protection required by 511.12 can be provided by a GFCI breaker if needed. Having said that....
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
