Hello, So it says Service Equipment has to be NOT attached to the building and not past 30' and within sight.
It then allow the Service Farther if a Service rated disconnecting means is supplied and NOT more then 30' away.
Question, Can this Service Rated DISCONNECTING Means Be attached to the building Such as a Recessed 3r panel . I don't see why not since it says Only Service Equipment can't be attached.
Just want to double check.
