winslowfam
- VA
Hi...I have an existing 5kv motor starter with overcurrent and fault protection built in. This starter is fed from a fused switch in a 5kv switchboard. The feeder conductor size from the switchboard to the starter is the same size as the motor leads. I know the motor leads are protected from overcurrent by the overload relays in the starter. The question is...is the feeder conductor from the switchboard also protected against overload by the motor overload relay and only protected against fault current by the feeder fused switch fuse ? Or does the feeder fused switch fuse need to be sized to protect the feeder conductors against overload as well as fault current? Is it all considered a motor circuit, or is it considered a branch circuit from the switchboard to the starter ? Thanks.
