Most 5kw shop heaters usually are controlled by stats integral to the unit, temp control, on-off, auto, fan, etc.
All the 10kw heaters I've install have an integral contactor that is controlled by low voltage t-stat mounted remotely.
I wish this option was available on the 5kw htrs.
I know there are htr relays that can perform this function, but the you get into ~$100 in mtl + labor.
I see a line voltage t-stat at the local box store that is rated for 28 amps and is being marketed for controlling shop htrs.
Question-
What is your preferred method of remotely controlling a 5kw heater?
I'm thinking about scenarios where the heater is mounted higher than the HO can conveniently access for controlling temperature.
Thanks!
Question-
Thanks!
