I am designing an addition to an existing service. The MDP is a 3Ph, 120/208, 600A, MLO with 3-200Amp distributiion breakers installed existing. Each 200 Amp breaker in the panel serves a branch 225Amp MLO panel. The service feeder conductors are 500MCM to the CT cabinet which is directly on the back side (exterior) to the MDP. The utility has also pulled 500MCM approx 150 ft to the utility pole mounted transformers (between CT cabinet and pole). I want to make sure that this is a violation as I think it is before I require an up-size of the service conductors. Am I correct.
