(2) Metal Frame of the Building or Structure The metal frame of the building or
structure, where any of the following methods are used to make an earth connection:
(1) 3.0 m (10 ft) or more of a single structural metal member in direct contact with
the earth or encased in concrete that is in direct contact with the earth
(2) The structural metal frame is bonded to one or more of the grounding electrodes
as defined in 250.52(A)(1), (A)(3), or (A)(4)
(3) The structural metal frame is bonded to one or more of the grounding electrodes
as defined in 250.52(A)(5) or (A)(6) that comply with 250.56, or
(4) Other approved means of establishing a connection to earth.
Sorry Bob......was only posting portions to try and find out more about this steel to aid...I will refrain from assistance....carry on...most certainly it would still be EARTHED if connected to the other parts of the system......
