JohnKr
- Hollywood, Fla
I have a question about the use of a 6 Pole Main Disconnect Switch. I have an application for a control panel that requires both 220VAC Single Phase and 460VAC Three Phase power. I want to use an ABB 6 Pole disconnect switch. Would there be a problem with the UL Standard if this switch were used with different voltages and phases on each side of the switch.
Thanks
Thanks
