Tomdiorio
- Pittsburgh pa
Hello all! I’m new to the forum, but not electrical industry. Used to work
in high voltage utilities now working in the residential sector.
Anyway, working on a job where the customer needs some interior wiring work done as well as connecting their new hot tub. They already have a Eaton CH 4 circuit 60 amp gfci sub panel installed when then built the house. 60 amp breaker feeding the sub panel from main panel.
Customers new hot tub requires a 50 amp gfci sub panel. I’m trying to save the customer some money, but not sure if the 60 amp gfci would be ok to run the 50 amp hot tub. Of course would use the proper wire for 60 amps to the tub.
One of the guys suggested moving the 60 amp gfci to the main panel and installing a standard 50 amp in the sub, but I don’t think NEC would like that! Ideally, I would like to just connect the tub to the 60 amp. Any suggestions to help the customer out?
thank you.
thank you.
