I've never seen a fuse panel with that configuration here in PA, and the largest fuses I've seen for them were 60A, so that would be my guess for the panel, but a lot of times guys would tap multiple disconnects and panels from the feeds to a fuse panel like that, so a "Whaddevah" Amp rating![]()
The third pullout makes it a little different than what most of us commonly see, otherwise there were a lot of 100 amp rated panels with two main sets of fuses. The one marked "main" killed power to everything except the other 60 amp pullout. There were 100 and 200 amp pullout fuse carriers, but they were not seen as often as 60 amp pullouts, especially in dwellings. I can think of one place right now where I know there is an old fuse panel (building built in 1950) that has pullout 200 amp mains and some 100 and 60 amp feeders supplied from it, all pull out style fuse holders.
I'm guessing your asking about the panel above the meter. That is an 8-16 Murry 100 amp panel. At least they are Murry breakers. The meter would be 100 amp and I'm guessing feeding the fuse panel. Fuse panel feeding the Breaker panel??
And the 100A and 200A fuses fit those same pullouts? I have some EK-4 fuses here with replaceable fuse strips, but they're rated 31-60A (on the label). Any fused services I saw around here larger than 60A had a separate disconnect with bladed fuses like a NON-100 or NON-200 Class H type fuse. Some had a non bladed type, but it was definitely larger than the little 60A plug fuses. Man, this is a trip down memory lane...
I never said they would fit in a 60 amp fuse holder, I was merely pointing out there were panels that had 100 and 200 amp fuse holders, they were more common in commercial installs than residential installs. Most residential installs just never had the load to need them.
Sorry, i read your post too quickly. Most light commercial installs that I saw were in town and had a 100 or 200A fused knife switch above the end box. Never saw that size in pullouts.
