For years i have used only the 60-degree column in table 310-16 to size conductors up to size 1. This method was based on what i read in NEC 110.C-1. This section of the code used to make perfect sense to me, but now, i am confused. This issue came up because i have seen several designs where #3s were being used for 100 amp feeders.
I recognize that i can size based on the 75 and 90-degree columns if i can prove the wire insulation and terminations. So, my question is, am i required to use the 60-degree column to size conductors up to #1?
