Dan coulstring
- Maine
In a manufacturing facilty-operator felt a shock.
One bench with multi-outlet assy, 2-printers,1 computer and a monitor plugged in.
With meter I had 60 V between all non-current carrying metal, including case of outlet assy- and the metal frames of surrounding equipment that was powered from a different recepatcle. I tried unplugging things one at a time and only when everything was unplugged did the 60V go away.
I took the outlet assy apart and found the EGC not attached at the entry point-none of the receptacles had an EGC or the frame. Reattached
Is this now safe and where did the 60V potential come from?
