600 amp heavy up
Energy-Miser
Maryland
Planning on putting a new panel to upgrade service from 400 amps to 600 amps in a residential installation. Would like to know if they make raintight troughs that can be altered in the field to any lenght. If someone knows of a manufaturer, please reply. Thanks, E/M.
That would be an extreme expense, JMO.
I don't understand the requirement of this, a raintight trough on a residence?
Why aren't you letting the wire be rated "W" and be done with it?
Are there any local UL fab shops on the Eastern Shore?
You might consider a plastic rated troughs or Square D which showed up first with the use of a search engine.
Lets see 8 x 8 x 72 inch (HxWxL) NEMA 3R $271 (not expanable)
4 x 4 x 12 inch (HxWxL) NEMA 3R $37.50 (not expanable)
Both need 1-10 days to deliever or greater.
quoted prices from: Here This has a nice table of various sizes.
Based on a search engine for nema 4X trough Here
Bills in the mail :)
Thanks for the info. We ended up with some 6x6 by 4 foot sections, and another shorter piece I believe made by utility (or unity?) manufacturing. You are right, they are not cheap! Fun to install too.
