We need to use a 480v Motor on a 600v source.
The motor is a 20A maximum, so we need a ~17kVA XFMR.
(480*20*1.73 = 16.6)
It also needs to be a NEMA 3 enclosure due to rain exposure.
It seems that all of the transformers this size, go from 15kVA to 30kVA.
The 15kVAs are ~100lbs, and the 30kVA are ~300lbs! They are also quite large in dimension.
Can you use a smaller Buck Boost transformer for 600 -> 480?
It seems that no one has a Buck Boost that does that ratio.
I know that Buck Boosts can be much smaller in size, and cheaper.
Thank you!
Thank you!
