FaradayFF
- California
Greetings fellas,
I have a design question - which would be preferable to use, a low voltage MCC or a Power panel? I'm looking at powering mostly HVAC loads, each load drawing approximately 45kVA. It seems both options will accomplish the intent, albeit Power panel has an advantage of a smaller footprint. The caveat here is that most loads connected to the source would be coincident, so from temperature perspective, it may make more sense to go with MCC, since it's got buckets for the breakers and is generally wider, providing more heat dissipation per unit area.
Thoughts?
EE
Thoughts?
EE
