Dustin Foelber
I have a residential meter bank that has a 400A disconnect protecting the 11 meters. The disconnect has gone bad and I need to replace it. Due to shortages in my area I have the option to use a 600V 3 Phase Disconnect. Is this a code violation? I can not think of any reasonable issue why not using one phase and having the disconnect rated for the additional voltage would be an issue but I am not 100% certain? Maybe fuse rating AIC of the fuses changes if you feed it with 240V volt vs 600V? Any feedback would be greatly appreciated.
