JohnDS
- Suffolk, Long Island
- Electrician
I haven't done this in a while but I do know that since it is a detached garage, that the sub panel needs its own ground rod. I have 3 questions:
1) this sub panel needs its own main breaker, out by the garage, correct?
2) can the main breaker be located in the sub panel or does it need to be outside the garage?
1) the grounds and neutrals still need to be separated, correct?
Thanks guys....total brain fart here and want to do it correct. Thank you.
