Was wanting to see what ideas others have on hooking up an portable generator mounted on a trailer. I was thinking of Mounting a 200A SE rated disconnect on load side of meter an then adding a 200A manual transfer switch an then feeding an existing 200A panel. Was wandering what method others would use to hook up generator to transfer panel. I was thinking the cheapest method would be to hard wire the Gen when needed, or maybe install a 200A pin an sleeve to bottom of transfer panel .
