golfer2018
Banned
- Laconia
So I’m installing low voltage 12vac luminaire to a deck post near a pool/spa/inground hot tub.. It is located little over 5 feet away from the inside wall and up 8 feet heigh. Art. 411.5 (b) says no less than 10 feet from nearest edge of pool unless permitted by article 680. So when I go to 680.22 (b)(6) it talks about within 5 feet with low voltage Luminaires. But my measurements are outside of 5 feet and 8 feet high . So when I look at 680.22 (b) 4 it looks like it just has to be rigidly attached because I’m over 5 feet heigh? I just don’t know if that means low voltage luminaries also ? What part of 680.22 does my installation fall under ? Thanks Steve
