Greentagger
- Texas
- Master Electrician, Electrical Inspector
Non metallic conduit from wet niche forming shell containing insulated #8 bonding conductor , if required to terminate in a j box , the j box has to be listed , labeled, and identified as a swimming pool junction box? Appears a regular run of the mill j box ( bell box, pvc jbox,etc.) can’t be used ? Also all bonding conductors and EGC’s from niche cords and #8s to be terminated on listed ground bar per 680.23(F)(2)(a), and 680.24(D)(F). Correct or am I off base? Thanks.
