680.25 (b) Pools
Cavie
SW Florida
Anyone else having trouble with this??? "Ground wire, along with feeder conductors, must go from pool panel to "Service Equipment". ( Main Breaker) right?. If this is an extended service, you must run to the outside main breaker, right? Now what do you do for an existing house and the service has only a 2 pole 200 amp disconect??? I'm being told to use the exception in (A) and allow it to go to the sub panel. Why is it safe for the existing and not for the new construction???
