JPerez/Paradise
- Southampton, NJ
As it relates to installing a remote panel board for a swimming pool does it require ground rods?? We have an inspector that says that it requires a set of ground rods to the panel board. This panel board is mounted on a post and is completely isolated from everything around. It is not mounted to a shed or any other type of building or structure. We would like to determine if this municipality is citing the code properly.
The panel board is fed by 1" pvc with individual conductors and an insulated equipment grounding conductor with its own over current protection in the main panel. Please advise. Thanks Jeff
