Tommyt63
New member
- Omaha Nebraska
If you use unencapsulated structural reinforcing steel (USRS) in the pool shell can you still use a #8 bare copper conductor for the perimeter surface? Or do you have to use the same USRS in the perimeter grid to extend to three feet. Under 680.26(B)(2)(b) Alternate Means it states that where USRS is not available you can use a single copper conductor if you follow a few more requirements. The words "where not available " confuse me. Clearly it was available it was used in the shell? Or as long as you bond at four uniformly space points then a single #8 or larger copper conductor ran between 18 and 24 inches around the contour of the pool perimeter is compliant. It is also difficult for me to understand how a single copper conductor can be as effective as a a steel wire mesh or USRS covering the entire three foot space extending out from the pools inside wall?
